[OSRS-PROJ] OGC WKT
Thu Oct 4 10:13:17 PDT 2001
Paul Ramsey wrote:
> Is there an expedient way to convert OGC Well-Known Text SRS
> representations to Proj4 representations? Even better, is it possible
> Proj4 will support WKT directly in the future?
> I am trying to put together an IMS-style front-end for mapserver and the
> true sticking point looks like it will be projections: IMS-clients
> expect to be able to ask for data in any projection they like, using WKT
> to define the projection they want.
Paul,
PROJ.4 doesn't have these services, but they are available as services on
the OGRSpatialReference object.  It can read/write WKT and also transform to
PROJ.4.
Let me know if you need details.
Best regards,
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
