[OSRS-PROJ] OGC WKT
Paul Ramsey pramsey at refractions.net
Thu Oct 4 10:26:12 PDT 2001
Frank Warmerdam wrote:
> PROJ.4 doesn't have these services, but they are available as services on
> the OGRSpatialReference object.  It can read/write WKT and also transform to
> PROJ.4.
> Let me know if you need details.
I am afraid I am not a C, or C++ guru like you and Dave. The project I
am doing right now is perl-on-mapscript, and the requirement is to
direct mapserver to do projections using WKT. Since mapserver only does
proj4 ... I am sort of at a loss. I have started writing a perl parser,
but am sure there are more details in the conversion than namespace
changes.
In the long run, having proj4 do WKT directly seems like a nice goal.
That way things like mapserver which use proj4 directly could use WKT
for configuration.
      __
     | Paul Ramsey
     | Refractions Research
     | Email: pramsey at refractions.net
     | Phone: (250) 885-0632
     \_
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
