[OSRS-PROJ] Error when forward projection with a polar stereographic projecti on.. Please help.
Fri Dec 6 08:02:12 PST 2002
Ray Bryan E 2Lt 314 OSS/OSW wrote:
> I have tried a forward projection with a stereographic projection with no luck.
> Are there any suggestions?
> Here is what I entered in the command prompt.
> proj +proj=stere +lat_ts=30d00N +lat_0=90 +lon_0=90d00W +k_0=1 +x_0=200 +y_0=200
> Here is the error I'm getting...
> projection initialization failure
> cause: major axis or radius = 0 or not given
> program abnormally terminated
> Here is what I found on the remotesensing.org website for a stereographic projection.
>  +proj=stere +lat_ts=/Latitude at natural origin/
>               +lat_0=90
>               +lon_0=/Longitude at natural origin/
> 	      +k_0=/Scale factor at natural origin/ (normally 1.0)
>               +x_0=/False Easting/
>               +y_0=/False Northing/
> I'm trying to do a forward projection with a polar stereographic projection.
Bryan,
You also need an ellipse definition.  This requirement is "assumed" in much
of the documentation.
Try:
proj +proj=stere +lat_ts=30d00N +lat_0=90 +lon_0=90d00W +k_0=1 +x_0=200 +y_0=200 +ellps=WGS84
By the way, those are pretty odd x_0 and y_0 values.  Is the value
easting and northing really 200 meters?
Best regards,
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
