[OSRS-PROJ] Conversion between Geographic CS's
Luis Mota luis.mota at iscte.pt
Wed Oct 2 17:53:10 PDT 2002
Hi.
First of all, I must say I have never used PROJ.4 before. I am posting
to this list because I am a user of PostGIS, which uses PROJ.4 to
perform transformations between Coordinate Systems (CS).
In PostGis, there is a transform function that is supposed to transform
between any kind of CS. As far as I have understood, the conversion
between projected CS's works fine, but now I am trying to convert
between geodetic CS's and everything is going wrong...
So, my questions to you would be:
- is it possible to convert between geodetic CS's?
- is this very different from converting between projected CS's?
I am sorry to post such a simple question, but I don't seem to
understand much from the online documentation...
Bye and thanks in advance
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
