[OSRS-PROJ] Conversion between Geographic CS's
Wed Oct 2 20:56:47 PDT 2002
Luis Mota wrote:
> Hi.
> First of all, I must say I have never used PROJ.4 before. I am posting
> to this list because I am a user of PostGIS, which uses PROJ.4 to
> perform transformations between Coordinate Systems (CS).
> In PostGis, there is a transform function that is supposed to transform
> between any kind of CS. As far as I have understood, the conversion
> between projected CS's works fine, but now I am trying to convert
> between geodetic CS's and everything is going wrong...
> So, my questions to you would be:
> - is it possible to convert between geodetic CS's?
> - is this very different from converting between projected CS's?
> I am sorry to post such a simple question, but I don't seem to
> understand much from the online documentation...
> Bye and thanks in advance
Luis,
By geodetic, I gather you mean lat/long coordinate system normally in degrees
based on an ellipsoid and a datum?
These would normally be described in PROJ.4 with a "known" datum like:
  +proj=latlong +datum=WGS84
or with a user defined datum (3 or 7 parameter transform) based on an
ellipsoid defined something like:
  +proj=latlong +ellps=GRS80 +towgs84=2,5,-15
I hope this helps.
Best regards,
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
