[OSRS-PROJ] Prime Meridian Support in PROJ.4
Gerald Evenden gerald.evenden at verizon.net
Thu Oct 3 18:36:53 PDT 2002
Frank Warmerdam wrote:
> Gerald Evenden wrote:
> > Just as an aside from the original author of proj.4:  prime meridian has no place
> > in proj.4.  Any offsets in longitude due to variations in coordinate system "prime
> > meridian" should be taken care of externally with adjustments to "lon_0"
> > parameter.
> Gerald,
> > I know my advice will be ignored but I could not resist expressing my displeasure
> > with the inclusion of PM code within the proj.4 library.  PMS, if you will.
Sorry, but I could not resist "Prime Meridian Syndrome."  :-)
> Well, the corruption started when I introduced support for converting
> between different datums. At that point I was trying to make PROJ.4 into
> a coordinate system conversion library rather than just a projections
> library.  I can see why you feel that is a perversion of the original vision
> of PROJ.4, and the focus of it's role, but that is the danger of open source.
> Your work can be adopted an taken in directions you never intended.
> That said, I think PROJ.4 is serving an important function for lots of other
> projects by taking on the larger role of coordinate systems conversion and
> that integrating that task in one library rather than two layered libraries
> has some benefits.
> Your advice isn't exactly disregarded ... your vision messages cause me lots of
> angst!  It just that user demand (and my own needs) has led me to take PROJ.4
> in a different direction than originally intended.  Obviously we all owe you
> alot as you did all the hard work ... the stuff that I am far from competent
> to do.  But in the end, I will still pursue the features I think are useful
> and needed,
I generally remain silent on changes to proj.4 and try to limit comments to
places where I feel things are going a little too astray.  But in all cases, please
take the comments as friendly suggestions.  I consider the version of proj.4
you and your group is distributing yours and these suggestions are only to remind
you that I'm still looking  over your shoulders.
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
