[OSRS-PROJ] Prime Meridian Support in PROJ.4
Glynn Clements glynn.clements at virgin.net
Sat Oct 5 12:29:55 PDT 2002
Clifford J Mugnier wrote:
> However, if a classical datum DOES use a Prime Meridian other than the
> Conventional International Origin (CIO) corresponding to Herstmonceaux
> Castle at Greenwich, England;
Herstmonceux Castle is in Herstmonceux, Sussex (50.9N 0.3E), which is
about 70 miles from Greenwich, London (51.5N, 0.0E).
The Royal Observatory was originally in Greenwich; it moved to
Herstmonceux shortly after WW2, but the meridian stayed put.
Glynn Clements <glynn.clements at virgin.net>
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
