[OSRS-PROJ] orthographic projection with proj4 and mapserver.
Gerald I. Evenden gerald.evenden at verizon.net
Thu Aug 14 08:03:17 PDT 2003
On Thu, 2003-08-14 at 10:21, Judd Taylor wrote:
> ----- Original Message -----
> From: "Craig Bruce" <csbruce at cubewerx.com>
> To: "[OSRS-PROJ]" <osrs-proj at remotesensing.org>
> http://www.cs.man.ac.uk/aig/staff/alan/software/gpc.html). Unfortunately,
> this takes forever to clip the larger polygons in that coastline set (~1.4
> million points).
~1.4m points seems like overkill for global maps.  I use a 5+k file to
do most of the small global plots on the PROJ.4 documentation.  If the
figure really fills a page I might go to a 50+k file.  Doing work for a
PC screen shouldn't need more than a 5k point file.
I am only talking here about coast line data
PS, many times I only use every third point of a 5k pt. file.
Gerald I. Evenden <gerald.evenden at verizon.net>
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
