[OSRS-PROJ] orthographic projection with proj4 and mapserver.
Norman Vine nhv at cape.com
Thu Aug 14 08:24:32 PDT 2003
Judd Taylor writes:
> > "Gerald I. Evenden" <gerald.evenden at verizon.net> wrote:
> > Proper graphical clipping is a tough problem.  I
> I could use some pointers in this arena as well, if anyone on this list has
> any. Right now I'm using the General Polygon Clipping (GPC) library to clip
> my polygons from the GSHHS coastline set (GPC website:
> http://www.cs.man.ac.uk/aig/staff/alan/software/gpc.html). Unfortunately,
> this takes forever to clip the larger polygons in that coastline set (~1.4
> million points).
> Anyone know how I can speed this up? Maybe a different library? Maybe a
> different format for the polygons? I can't seem to find any good references
> for this sort of thing anywhere online. Any advice would be appreciated!
Itertively reduce the resolution of the data so that you have several data sets
each appropriate for a range of scales
You could also clip these into areas and then you would only need be
concerned with polygons in those areas that are in view
HTH
Norman
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
