[OSRS-PROJ] orthographic projection with proj4 and mapserver.
Norman Vine nhv at cape.com
Thu Aug 14 10:23:30 PDT 2003
Judd Taylor writes:
> I'd be very interested in any algorithms like Norman described  that clip
> the main polygons into areas, without showing the boundries between areas.
> Any links/examples?
Umm.... didn't mention you were using GPC
some simplistic but effective areas for the globe
might be just the upper and lower quadrants
( 8 areas total)
More sophisticated areas can be based on a
recursive platonic solid, but any structure
topologically equivalant to a sphere will do
No reasons the boundaries will show unless
you draw them as the polygonal pieces should
just abut if the math is done correctly
HTH
Norman
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
