[OSRS-PROJ] orthographic projection with proj4 and mapserver.
Thu Aug 14 06:53:12 PDT 2003
Tom H wrote:
> Hi list,
> I have an orthographic projection working with mapserver and proj4 here;
> http://www.scriptsupport.co.uk/images/mapserv3.png
> the problem is that around the edges, the on-the-fly projection seems to
> be creating area that is not defined on the projection, and is being dumped
> into the centre of the image. and the interpolation of the boundary is creating
> lines that cause that "shards" effect on the image.
Tom,
I think this problem is in either the pj_transform() function in PROJ, or the
mapproj.c code in mapserver, not checking for projection errors properly (or
at all!).  If you can prepare a sample mapfile, data file and "shp2img"
argument list that produces the errors you showed then please submit as a
bug in the MapServer bugzilla and I will try to dig into it.
As Gerald points out, the returning of 0,0 is not likely caused by the core
PROJ.4 functions which seem to work fine.
Thanks,
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
