[OSRS-PROJ] PROJ.4 usage in mapserver system - orthographic usage thread
Gerald I. Evenden
gerald.evenden at verizon.net
Thu Aug 14 19:49:19 PDT 2003
I got curious about this "mapserver" system and its relation to
PROJ.4 so I pulled it down and took a look at it.
Routines of interest seem to be mapproject.c and mapresample.c
and calls to pj_transform and pj_fwd.
I noted that the output of pj_fwd was *not* tested for error
in mapproject.c. The output of pj_transform was checked
(functional return) but I could not find it in the mapserver
distribution and assume it was your value added to PROJ.4.
If the program was used so that data went directly through
pj_fwd/inv, per the second half of the function msProjectPoint
then failure will occur since the return will be MS_SUCCESS
regardless of the success of the pj_fwd/inv call.
The patch appears obvious but I will not attempt it until I
successfully install the system. I suspect the pj_transform
is related to datum changes so I can ignore it (dummy procedure)
for non datum shift usage.
Gerald I. Evenden <gerald.evenden at verizon.net>
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
