[OSRS-PROJ] proj.4 in VB
Thomas Flemming tf at ttqv.com
Thu Jun 26 00:16:34 PDT 2003
Hello,
the main problem is, that the proj.dll is not usable by VB because of the
function declarations. They have to be declared with __stdcall.
So not:
   void pr_xxx(..);
but:
   #include <windows.h>
   void __stdcall pr_xxx(..);
Then it should work.
Thomas
For more details in this see
Christopher Pouliot schrieb:
> Hello,
> I have downloaded the proj.dll file (v4.4.6) and am trying
> unsuccessfully to use it in Visual Basic.  The simple initialization
> code below causes a fatal error in VB and crashes the program.  My
> experience working with external DLLs is limited so any assistance or
> sample VB code would be greatly appreciated.
> Private Declare Function pj_init Lib "c:\software\proj\bin\proj.dll"
> (ByVal argc As Integer, ByRef argv() As String) As String
> Private Sub Command1_Click()
>   Dim anArr(2) As String
>   Dim aResponse As String
>   anArr(0) = "proj=utm"
>   anArr(1) = "zone=11"
>   anArr(2) = "ellps=GRS80"
>   aResponse = pj_init(3, anArr)
> End Sub
> Thank you,
> Chris
> PROJ.4 Discussion List
> See http://www.remotesensing.org/proj for subscription, unsubscription
> and other information.
**   Dipl.-Ing. Thomas Flemming
**      Software Development
**  thomas.flemming at touratech.de
**          tf at ttqv.com
**      http://www.ttqv.com
** ... und immer dem Pfeil nach!
