[OSRS-PROJ] proj.4 in VB
Alexander Weidauer alex.weidauer at huckfinn.de
Fri Jun 27 03:56:46 PDT 2003
Hi Thomas but if you use the  _cdecl it should work
here a code snippet from my API
Function  _pj_init_plus_path(const Args: PChar; const Path: PChar):
           PProjPJ ;cdecl;external LibName;
{ forward projection normally Longitude Latitude to plain xy Coordinates }
Function  _pj_fwd(ProjLP:TProjLP; projPJ:PProjPJ):TProjXY;
{ inverse projection normally plain xy coordinates to longitude latitude
coordinates }
Function  _pj_inv(ProjXY:TProjXY; projPJ:PProjPJ):TProjLP;
Bye Alex
Thomas Flemming schrieb:
> Hello,
> the main problem is, that the proj.dll is not usable by VB because of
> the function declarations. They have to be declared with __stdcall.
> So not:
>   void pr_xxx(..);
> but:
>   #include <windows.h>
>   void __stdcall pr_xxx(..);
> Then it should work.
> Thomas
> For more details in this see
> Christopher Pouliot schrieb:
>> Hello,
>> I have downloaded the proj.dll file (v4.4.6) and am trying
>> unsuccessfully to use it in Visual Basic.  The simple initialization
>> code below causes a fatal error in VB and crashes the program.  My
>> experience working with external DLLs is limited so any assistance or
>> sample VB code would be greatly appreciated.
>> Private Declare Function pj_init Lib "c:\software\proj\bin\proj.dll"
>> (ByVal argc As Integer, ByRef argv() As String) As String
>> Private Sub Command1_Click()
>>   Dim anArr(2) As String
>>   Dim aResponse As String
>>     anArr(0) = "proj=utm"
>>   anArr(1) = "zone=11"
>>   anArr(2) = "ellps=GRS80"
>>     aResponse = pj_init(3, anArr)
>> End Sub
>> Thank you,
>> Chris
>> PROJ.4 Discussion List
>> See http://www.remotesensing.org/proj for subscription, unsubscription
>> and other information.
