[Proj] -f arguments
Marinos Charalampakis mariner at otenet.gr
Wed Jul 21 02:07:31 PDT 2004
I would also like to remind you that i run PROJ 4.4.6 for WIN32. I don't
know if this causes the problem...
M.
----- Original Message -----
To: "Marinos Charalampakis" <mariner at otenet.gr>
Cc: <>
Sent: Tuesday, July 20, 2004 11:06 PM
Subject: Re: [Proj] -f arguments
> Marinos Charalampakis wrote:
> > Hi,
> > I would like to convert some UTM coordinates to decimal degrees. I used
> > proj and worked, but the results are in DMS. I can't make the -f format
> > work, under windows. Any suggestions?
> Marinos,
> It seems to work ok for me.  I tried something like this:
> warmerda at gdal2200[138]% proj -f "%g" -I +proj=utm +zone=11 +datum=WGS84 <<
EOF
> ? 45000 1100000
> ? EOF
> -121.147        9.92534
> Make sure you use a valid format string.  Something like "%.12f" might be
> appropriate if you want alot of precision.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
