[Proj] epsg:2855 projection problem
Thomas Chesky thomaschesky at yahoo.com
Fri Jul 23 20:52:52 PDT 2004
Hello,
I have a King County, WA dataset (shapefile) which I am trying to use with Mapserver.
It is in " NAD83(HARN) / Washington North (ftUS) " projection (epsg:2855)
but is translated to an invalid lat/lon extent:
minx="-111.388" miny="46.3886" maxx="-106.113" maxy="49.1724"
without being a GIS expert (or anything even close) I can only imagine that the PROJ.4 library used by the Mapserver causes it. Is there any known issue with the epsg:2855 definition of PROJ.4 ?
Can somebody provide me the Mapserver PROJECTION definition for the same but not in the "init=epsg:2855" format. Maybe the problem is with the epsg lookup table and if defined by the full projection syntax, I got the right extent, but I am not sure how to define the proper PROJECTION syntax (other than the epsg one)
Thanks
Do you Yahoo!?
New and Improved Yahoo! Mail - Send 10MB messages!
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20040723/afe6a8d1/attachment.html>
