[Proj] PROJ 4.4.8 - Release Candidate
Markus Neteler neteler at itc.it
Wed May 5 05:40:40 PDT 2004
On Tue, May 04, 2004 at 02:25:50PM -0400, Frank Warmerdam wrote:
> Markus Neteler wrote:
> >Frank,
> >thanks for the updates. However, the problem with prime meridian
> >seems to be unsolved.
> ># LatLong to Italian Gauss Boaga Fuso Ovest (1st Zone):
> >cs2cs -v +proj=latlong +datum=WGS84 +to +init=epsg:26591 \
> >         +towgs84=-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68
> >11d12'26E 46d06'17N 100
> >-251428.83      5362296.50 54.97
> > -> This result is wrong.
> ># Using the old method:
> >cs2cs -v +proj=latlong +datum=WGS84 +to +proj=tmerc +lat_0=0 +lon_0=9 \
> >       +k=0.999600 +x_0=1500000 +y_0=0 +ellps=intl +units=m \
> >       +towgs84=-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68 \
> >       +no_defs
> >1670617.27      5108072.04 54.97
> > -> This looks correct.
> >In my opinion the nad/epsg file entries for 26591 and 26592
> >and maybe all others with +pm parameter are wrong (more than
> >60 projections). Or the prime meridian is not applied correctly.
> >Interesting: The lon_0 values seem to be correct in GDAL/gcs.csv
> >Probably I am missing something (please let me know),
> Markus,
> Now I remember why I put off dealing with this for so long.  There was
> a tangle of problems and mistaken assumptions in the way I was processing
> various longitudinal values relative to prime meridians through from the
> EPSG to the PROJ.4.  I have corrected the code in GDAL/OGR used to generate
> the epsg file, and issued a new PROJ 4.4.8 release with the corrected
> epsg file.  The first example you gave now gives correct results.
> Please verify as soon as you get a change.
Frank,
it was a good idea to insist :-) Finally it looks reasonable:
# ---- From Coordinate System ----
#Lat/long (Geodetic)
# +proj=latlong +datum=WGS84 +ellps=WGS84 +towgs84=0,0,0
# ---- To Coordinate System ----
#Transverse Mercator
#       Cyl, Sph&Ell
# +init=epsg:26591 +towgs84=-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68
# +proj=tmerc +lat_0=0 +lon_0=-3.45233333333333 +k=0.999600 +x_0=1500000
# +y_0=0 +ellps=intl +pm=rome +units=m +no_defs
Will you update the source package on the web site and the RPM?
Now let's hope that the vendors pick up the package quickly.
I have just created one for Mandrake 9.2 (so we could point the
GRASS users to the site).
Best regards
 Markus Neteler
