[Proj] wrong values for shift utm ed50 to utm wgs84
Christoph Dohmen chdohmen at gmx.de
Wed May 26 23:06:56 PDT 2004
Hi all,
I have to translate several values from utm ed50 to utm wgs84. I tried this
with several tools and got different values :-( And especially using cs2cs I
got definitly _wrong_ values. Just an example:
values to translate as metre values from zone 32 north in ed50:
488000 E
5902000 N
using the demo-version of transdat I get the following:
487916.915498 E
5901796.048890 N
using the online-tool from http://www-ipf.bau-verm.uni-karlsruhe.de/cgi-bin/
trafo.tcl I get:
487921.76 E
5901788.00 N
and using cs2cs (from proj 4.4.8) I get:
488000.00 E
5902000.00 N
with the params: cs2cs +proj=utm +ellip=intl +to +proj=utm +ellip=WGS84
+datum=WGS84  << EOF
> 488000 5902000
> EOF
using cs2cs +proj=utm +a=6378388.0 +b=6356911.94613 +zone=32 +to +proj=utm
+ellps=WGS84 +zone=32 << EOF with the same values result in:
488000.36 E
5901787.27 N
and cs2cs -v +init=epsg:23032 +to +init=epsg:32632 << EOF for the above
mentioned point results also in:
488000.36 E
5901787.27 N
