[Proj] Roussilhe Projection
Gerald I. Evenden gerald.evenden at verizon.net
Mon Oct 31 13:42:38 PST 2005
Because of a power outage last night I am not quite as far as I wanted on the
C translation of the correction code.  It is completed and preliminary checks
compare OK with the literal translation of the Pascal code.  The size of the
revised procedure is 27k vs, 64k for the literal routine.  I have not checked
timing yet but I expect at least the same order of magnitude of
performance improvement.  Should now fit in your PDA. ;-)
I will finish it with a filter program that one can use as a pipe filter in
front of or back of [l]proj.  The only options will be zone number and
forward-inverse flag.
Lastly, how should it be distributed?  I can email it to interested parties.
Jerry and the low riders:Daisy May and Joshua
"The being cannot be termed rational or virtuous,
who obeys any authority, but that of reason."
---Mary Wollstonecraft 1792
