Krovak fix (was: [Proj] Old problems)
Maciek Sieczka werchowyna at epf.pl
Wed Jan 4 14:13:35 PST 2006
On śro, 2006-01-04 at 13:26 -0500, Frank Warmerdam wrote:
> Frank writes:
> > would likely dig into some of the Krovak,
> Gerald writes:
> > What is the problem with Krovak?
> I think it is related to the axis orientation.   I am *wanting* to
> add +axis directives to the coordinate system description to
> support different axis orientations instead of creating a new
> projection type for alternate axes.
Frank,
Does that mean that Radim's workaround to support Slovak and Czech
coordinate systems
http://mpa.itc.it/radim/jtsk/PJ_krovak.c.patch
won't be neccessary anymore?
Maciek
Szykuje się długa i mroźna zima? Nie pękaj!
Hurtownia prezerwatyw  http://www.jak-pol.com.pl/
