Krovak fix (was: [Proj] Old problems)
Wed Jan 4 15:34:46 PST 2006
On 1/4/06, Maciek Sieczka <werchowyna at epf.pl> wrote:
> On śro, 2006-01-04 at 13:26 -0500, Frank Warmerdam wrote:
> > Frank writes:
> > > would likely dig into some of the Krovak,
> > Gerald writes:
> > > What is the problem with Krovak?
> > I think it is related to the axis orientation.   I am *wanting* to
> > add +axis directives to the coordinate system description to
> > support different axis orientations instead of creating a new
> > projection type for alternate axes.
> Frank,
> Does that mean that Radim's workaround to support Slovak and Czech
> coordinate systems
> http://mpa.itc.it/radim/jtsk/PJ_krovak.c.patch
> won't be neccessary anymore?
Maciek,
It is my intention that a generic solution would be instituted,
and then, presumably, that patch would not be required.
Best regards,
