[Proj] wgs point (lat-lon 'NMEA' to N-E 'metric') "was (lat-lon 'degres' to N-E 'metric')"
Massimo Di Stefano massimodisasha at yahoo.it
Tue Mar 27 11:22:53 PDT 2007
Yes it is a NMEA gps output
i'm tring to red it directly from a seria device,
reformat it in a rght format readable by proj
can i trasnfor it from :
4051.1749  N   01415.5317   E
to
40 51 17.49 N  014 15 53.17
that isn't the same of:
40.511749  N   014.155317   E
right?
(sorry for this basilar question!)
have you any suggestion/comment to
read directly the NMEA format in proj !
i'm playing with awk or other bash command to reformat this...
but i'm a newbie student...:-)
...  have you any suggestion about ?
thanks,
Massimo
Il giorno 27/mar/07, alle ore 19:03, proj-request at lists.maptools.org
ha scritto:
> Massimo,
> This looks like an NMEA GPS format. Eg DDDMM.mmmmm
> You might need to re-format the values to something like decimal
> degrees
> (DDD.dddddddddd) or DD MM SS.ss to use proj for the conversion.
> Regards
> Andrew
