[Proj] FW Tools 1.2.2 beginner
Thu May 10 20:47:01 PDT 2007
> Conor O'Donoghue wrote:
> > 1) I need help with choosing the most appropriate
> > utilitiy (GDAL or Proj for example). My objective
> > is to forward re-project, or warp, tiff's (vector files
> > later). I have no need to use the functionality with
> > another program, so i think the command line should be
> > fine.
Frank:
> Generally speaking you would use gdalwarp to warp a
> raster image.
Conor:
> However, before I start I would like to be
> clearer....... Could I run proj.4 from the command
> line directly without GDALwarp and if so, why would I
> need to use GDALwarp?
proj will reproject between coordinate systems (pure numbers).
   (e.g. convert a lat/lon position to UTM coords)
gdalwarp will twist/turn/strech/warp a GeoTIFF image.
Hamish
