[Proj] Specify a different directory for gsb files
Ervin Oswaldo Escobar Salazar ervinoswaldoescobar at gmail.com
Tue Sep 4 00:19:28 PDT 2007
???? Your answer is certainly off-topic... I am not asking how to execute
shell commands in ASP. Did you read my complete question? Don't think so.
2007/8/31, Eric Miller <EMiller at dfg.ca.gov>:
> Setting environment variables or running shell commands from ASP is pretty
> far off-topic for this list.  The answer certainly depends on just how you
> plan to execute a shell command from ASP.
> >>> On 8/31/2007 at 1:12 AM, "Ervin Oswaldo Escobar Salazar"
> <ervinoswaldoescobar at gmail.com> wrote:
> > Sorry, i must correct something...
> > The option of creating an environment variable works if you do not
> specify
> > the path of the file in the command line. I said that didn't work but is
> not
> > true. After some tests, i confirm that if you have set the variable to
> the
> > correct path, and use the options +nadgrids=myfile.gsb, PROJ makes the
> NTV2
> > transformation correctly.
> > Sorry for the mistake. Now i must enquire how to fix an environment
> variable
> > using ASP, and without administative privileges.
> > Any other ideas would be appreciated.
> > Thanks in advance for your help.
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20070904/ddb97a89/attachment.html>
