[Proj] Specify a different directory for gsb files
Tue Sep 4 05:15:02 PDT 2007
Ervin Oswaldo Escobar Salazar wrote:
> ???? Your answer is certainly off-topic... I am not asking how to
> execute shell commands in ASP. Did you read my complete question? Don't
> think so.
Ervin,
I think people are unclear on how you are running your PROJ.4 operations.
If you are running cs2cs as a shell command from ASP.NET then this is
very pertinent since the easiest way of affecting the environment for
that command is to run a .BAT file that sets the environment variable locally
and then runs cs2cs.
Of course, you may not be running cs2cs from your application, but nevertheless
the answer was an attempt, with the information available, to answer your
specific requirement.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
