[Proj] General Inverse Transformation
support.mn at elisanet.fi support.mn at elisanet.fi
Sat Oct 4 04:30:41 PDT 2008
An interesting paper about a general inverse transformation:
http://atlas.selcuk.edu.tr/paperdb/papers/130.pdf
Here is the conclusion:
4.  CONCLUSION
For the projections handled in this article forward projection functions are complex. To
derive the inverse projections fuctions, a specific method is required. The algorithm presented
here is  Newton-Rapson iteration with Jacobian matrices. It is applied to three world
projections. It can also be adapted for all cartographic projections in order to derive inverse
equations.
Since the manual calculation using this algortihm is not easy, a computer program is
needed. With such a program, data capture from analog maps produced using the projections
above can be possible. So captured data can also be easily integrated into any GIS system.
Janne.
