[Proj] Building for and calling from g95-MinGW
    Arjan van Dijk
    Arjan.van.Dijk at rivm.nl
    Wed Feb 25 04:40:36 PST 2009
> I downloaded a fresh install of MinGW and Msys just now and the
> ./configure && make && make install worked without a glitch. So probably
> upgrading to the newest version of MinGW shoudl solve your problems.
This suggestion from Paul has led to a nice file named libproj.a.
When used in combination with a sample program based on the
bit of code shown on the Proj site under proj_api (the code
contains errors!!) this library shows its power: it works!
Then Fortran. With some help from people from comp.lang.fortran
I managed to construct a so-called Module that should interface
with the C-functions pj_init_plus and pj_transform in libproj.a.
The module compiles and produces object code. Even my sample
Fortran program compiles, but it refuses to link: the sample
program calling pj_init_plus cannot find routine pj_init_plus.
Does anyone have a suggestion of how to proceed?
Once I'll have a working Fortran sample, I'll post the solution
to this list anyhow.
Regards,
Arjan
Disclaimer RIVM
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20090225/a7696302/attachment.html>
More information about the Proj
