[Proj] Building with fresh gcc snapshot on Windows-XP fails
Arjan van Dijk Arjan.van.Dijk at rivm.nl
Fri Feb 27 00:54:15 PST 2009
Hi!
After Paul Hiemstra gave me the hint to make a fresh install of MinGW,
I managed to build the Proj-4 library libproj.a on my Win-XP box.
Then I encountered problems with the gfortran version included with that
gcc collection,
and someone pointed me at an ultimately fresh gcc snapshot, which
can be downloaded from www.equation.com.
My fortran performance was greatly boosted by this upgrade,
but Proj-4 now refuses to be built. Again... Of course I still have the
old library from the gcc version that I installed some days ago, but I
don't like
having to have two gcc versions for all the different needs.
The gcc version that builds Proj-4 without problems is:
$ gcc -v
Reading specs from c:/mingw/bin/../lib/gcc/mingw32/3.4.5/specs
Configured with: ../gcc-3.4.5-20060117-3/configure --with-gcc --with-
gnu-ld --with-gnu-as --host=mingw32 --target=mingw32 --prefix=/mingw
enable-threads --disable-nls --enable-languages=c,c+
+,f77,ada,objc,java --disable-win32-registry --disable-shared --
enable-
sjlj-exceptions --enable-libgcj --disable-java-awt --without-x --
enable-java-gc=boehm --disable-libgcj-debug --enable-interpreter --
enable-hash-synchronization --enable-libstdcxx-debug
Thread model: win32
gcc version 3.4.5 (mingw-vista special r3)
The snapshot that has better Fortran support but that crashes building
Proj-4 is:
$ gcc -v
Built by Equation Solution <http://www.Equation.com>.
Using built-in specs.
Target: i386-pc-mingw32
Configured with: ../gcc-4.4-20090220-mingw/configure
--host=i386-pc-mingw32 --build=x86_64-unknown-linux-gnu
--target=i386-pc-mingw32
--prefix=/home/gfortran/gcc-home/binary/mingw32/native/x86_32/gcc/4.4-20090220
--with-gcc --with-gnu-ld --with-gnu-as --disable-shared --disable-nls
--disable-tls
--with-gmp=/home/gfortran/gcc-home/binary/mingw32/native/x86_32/gmp
--with-mpfr=/home/gfortran/gcc-home/binary/mingw32/native/x86_32/mpfr
--enable-languages=c,fortran,c++
--with-sysroot=/home/gfortran/gcc-home/binary/mingw32/cross/x86_32/gcc/4.4-20090220
--enable-libgomp --enable-threads=win32 --disable-win32-registry
Thread model: win32
gcc version 4.4.0 20090220 (experimental) (GCC)
Using this gcc, ./configure ran okay, but "make" crashed:
$ make
Making all in src
make[1]: Entering directory `d:/Arjan/proj/proj-4.6.1/src'
c:/mingw/bin/make  all-am
make[2]: Entering directory `d:/Arjan/proj/proj-4.6.1/src'
C:/msys/1.0/bin/sh.exe ../libtool --tag=CC   --mode=compile gcc -
DHAVE_CONFIG_H -I. -DPROJ_LIB=\"/usr/local/share/proj\"     -g -O2 -MT
jniproj.lo -MD -MP -MF .deps/jniproj.Tpo -c -o jniproj.lo jniproj.c
Xjniproj.Tpo -c -o jniproj.lo jniproj.lo
libtool: compile: libobj name `jniproj.Tpo -c -o jniproj.lo
jniproj.lo' may not contain shell special characters.
rm: invalid option -- c
Try `rm --help' for more information.
 gcc -DHAVE_CONFIG_H -I. "-DPROJ_LIB=\\/usr/local/share/proj\" -g -O2 -
MT jniproj.lo -MD -MP -MF .deps/jniproj.Tpo -c -o jniproj.lo
jniproj.c"  -DDLL_EXPORT -DPIC -o .libs/jniproj.Tpo -c -o jniproj.lo
jniproj.o
gcc.exe: jniproj.o: linker input file unused because linking not done
jniproj.c" -o jniproj.Tpo -c -o jniproj.lo jniproj.o >/dev/null 2>&1
mv -f .deps/jniproj.Tpo .deps/jniproj.Plo
mv: cannot stat `.deps/jniproj.Tpo': No such file or directory
make[2]: *** [jniproj.lo] Error 1
make[2]: Leaving directory `d:/Arjan/proj/proj-4.6.1/src'
make[1]: *** [all] Error 2
make[1]: Leaving directory `d:/Arjan/proj/proj-4.6.1/src'
make: *** [all-recursive] Error 1
Somehow the new gcc version cannot compile the same code that went
allright with the old version, and that had led to a working C sample.
Is the Proj-4 project "very sensitive" or "less generic"? Or is there a
bug in the gcc snapshot?
Arjan
Disclaimer RIVM
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20090227/e5a8f8ca/attachment.html>
