[Proj] Standard projection for Mediterranean basin
Clifford J Mugnier cjmce at lsu.edu
Mon Feb 15 09:01:20 PST 2010
So?
Keep the parameters and just use Authalic Latitude.
Easy.
Clifford J. Mugnier, C.P., C.M.S.
Past National Director (2006-2008),
Photogrammetric Applications Division
American Society for Photogrammetry and Remote Sensing
and
Chief of Geodesy,
Center for GeoInformatics
Department of Civil Engineering
Patrick F. Taylor Hall 3223A
LOUISIANA STATE UNIVERSITY
Baton Rouge, LA  70803
Voice and Facsimile:  (225) 578-8536 [Academic]
Voice and Facsimile:  (225) 578-8925 [Research]
Honorary Life Member of the
Louisiana Society of Professional Surveyors
Member Emeritus of the ASPRS
Member of the Americas Petroleum Survey Group
http://www.asprs.org/resources/GRIDS/
From: proj-bounces at lists.maptools.org on behalf of Gerald I. Evenden
Sent: Mon 15-Feb-10 08:30
To: PROJ.4 and general Projections Discussions
Subject: Re: [Proj] Standard projection for Mediterranean basin
On Sunday 14 February 2010 11:46:30 pm Clifford J Mugnier wrote:
> From 1925 to 1946, there was a "British Grid" used by the Allied Forces in
> the Mediterranean.  The British Army (GSGS) established the "Mediterranean
> Zone" for the secant Lambert Conical Orthomorphic Projection where the
> central meridian was 29° East of Greenwich, and the latitude of origin was
> 39° 30' N, the scale factor at origin was 0.99906, the False Easting was
> 900 km, and the False Northing was 600 km.
> See my column in PE&RS for December of 2002 on Greece.
I had the inference that the request was for an equal-area projection---a mode
that I consider preferable for thematic purposes.
The whole religious complexion of the modern world is due
to the absence from Jerusalem of a lunatic asylum.
-- Havelock Ellis (1859-1939) British psychologist
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20100215/86ffb0be/attachment.html>
