[Proj] +axis switch to control axis orientation
Tue Mar 9 07:45:49 PST 2010
support.mn at elisanet.fi wrote:
> Hello,
> I am only worried that the new development in proj4 is lost due
> to some formal detail?
> At least if someone could make a document about the new features
> and how to use them? That would be nice. There are many newcomers
> that need last time information about the proj4 development.
Janne,
I'm a bit lost with regard to what you want.  It is my intention to document
the +axis at:
   http://trac.osgeo.org/proj/wiki/GenParms
 > New features could be separated using new names with improved functions
 > so that old compilations would continue to be as they were?
The +axis feature should have no impact on those using the library who do
not incorporate +axis into their coordinate system descriptions.
Perhaps you can explain a bit more if this does not satisfy your needs?
Best regards,
