[Proj] Probably the dumbest question of all
Franz Schiller franzschiller1975 at gmail.com
Fri May 21 07:42:03 PDT 2010
Greetings
I've been using PROJ4 in GDAL and in GRASS but now, I need to do some GCP's
evaluation and I have a very dumbest question:
- I'm using  GOOGLE Earth to retrieve GCP and I want to know what is their
EPSG code? As far as I know GOogle Earth uses WGS84 and I believe to be EPSG
4326 but I'm not sure because its projection is lat long and GOogle Earth's
WGS84 is UTM.
Thanks
Franz
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20100521/b309f1f1/attachment.html>
