[Proj] Probably the dumbest question of all
Kyle Shannon ksshannon at gmail.com
Fri May 21 08:35:05 PDT 2010
Franz, I believe all google earth is in WGS84/EPSG:4326, but it can display
in utm.  You can change the display in Tools->Options.
kss
Kyle Shannon
Physical Science Technician
RMRS Fire Sciences Lab
Fire, Fuels & Smoke - RWU 4405
5775 Highway 10 W.
Missoula, MT 59808
(406)829-6954
kshannon at fs.fed.us
On Fri, May 21, 2010 at 8:42 AM, Franz Schiller <franzschiller1975 at gmail.com
> wrote:
> Greetings
> I've been using PROJ4 in GDAL and in GRASS but now, I need to do some GCP's
> evaluation and I have a very dumbest question:
> - I'm using  GOOGLE Earth to retrieve GCP and I want to know what is their
> EPSG code? As far as I know GOogle Earth uses WGS84 and I believe to be EPSG
> 4326 but I'm not sure because its projection is lat long and GOogle Earth's
> WGS84 is UTM.
> Thanks
> Franz
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20100521/f65b2c83/attachment.html>
