[Proj] problem in transform 32719 to 24879
Jose Gonçalves jagoncal at gmail.com
Mon Jan 24 08:08:04 PST 2011
Patricio
The problem is that you don't have a datum transformation for the second
coordinate system. You should have something like:
.... +to +proj=utm +zone=19 +south +ellps=intl +units=m +no_defs
+towgs84=-288,175,-376
I got these parameters from ArcGIS. There are several other sets of datum
parameters, probably more adequate for different areas.
Regards
José A. Gonçalves
2011/1/24 Patricio Cifuentes Ithal <pcifuentes at siigsa.cl>
> Hi list!,
> I’ have a problem,  I’ need transforrm one point  of projection 32719to
> 24879,
> Point 32719
> 362802.140         7955337.740
> Example:
> cs2cs +proj=utm +zone=19 +south +ellps=WGS84 +datum=WGS84 +units=m +no_defs
> 362796.55       7955312.55 0.00 (is incorrect!!)
> The real transform is
> 362996.74417800002      7955670.922740000
> Why not transform correctly? I missing something?
> *Patricio Cifuentes Ithal*
> Ingeniero en Informática
> Unidad de Informática
> Fono : 02 - 334 73 69
> www.siigsa.cl
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20110124/c3740e52/attachment.html>
