[Proj] problem in transform 32719 to 24879
Patricio Cifuentes Ithal pcifuentes at siigsa.cl
Tue Jan 25 11:55:41 PST 2011
José,
Exactly!!!
Thanks for the help!
Ingeniero en Informática
Unidad de Informática
Fono : 02 - 334 73 69
www.siigsa.cl
De: Jose Gonçalves [mailto:jagoncal at gmail.com]
Enviado el: lunes, 24 de enero de 2011 13:08
Para: pcifuentes at siigsa.cl; PROJ.4 and general Projections Discussions
Asunto: Re: [Proj] problem in transform 32719 to 24879
Patricio
The problem is that you don't have a datum transformation for the second
coordinate system. You should have something like:
.... +to +proj=utm +zone=19 +south +ellps=intl +units=m +no_defs
+towgs84=-288,175,-376
I got these parameters from ArcGIS. There are several other sets of datum
parameters, probably more adequate for different areas.
Regards
José A. Gonçalves
2011/1/24 Patricio Cifuentes Ithal <pcifuentes at siigsa.cl>
Hi list!,
I’ have a problem,  I’ need transforrm one point  of projection 32719to
24879,
Point 32719
362802.140         7955337.740
Example:
cs2cs +proj=utm +zone=19 +south +ellps=WGS84 +datum=WGS84 +units=m +no_defs
362796.55       7955312.55 0.00 (is incorrect!!)
The real transform is
362996.74417800002      7955670.922740000
Why not transform correctly? I missing something?
www.siigsa.cl
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20110125/3103652d/attachment.html>
