[Proj] cs2cs giving different result than ImportportFromProj4 in a C# program
Bjørn Krangnes bkr at devonor.com
Thu Jan 27 07:45:54 PST 2011
cs2cs is giving this result (Irish Transverse Mercator to IrishGrid75):
C:\Program Files (x86)\FWTools2.4.7>cs2cs +proj=tmerc +lat_0=53.5 +lon_0=-8
+k=0
.999820 +x_0=600000 +y_0=750000 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m
+no
_defs +to +proj=tmerc +lat_0=53.5 +lon_0=-8 +k=1.000035 +x_0=200000
+y_0=250000
+a=6377340.189 +b=6356034.447938534
+towgs84=482.530,-130.596,564.557,-1.042,-0.
214,-0.631,8.15 +units=m +no_defs
600000.0 700000.0
200049.28       199965.72 -54.78
The correct result is:  E: 200049.410 N: 199965.743
The result from cs2cs is very close to the correct result.
But when I use the following code in a c# program the result is not the same
as cs2cs
SpatialReference input = new OSGeo.OSR.SpatialReference(null);
SpatialReference output = new OSGeo.OSR.SpatialReference(null);
int istati = input.ImportFromProj4("+proj=tmerc +lat_0=53.5 +lon_0=-8
+k=0.999820 +x_0=600000 +y_0=750000 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0
+units=m +no_defs");   // ITM
int istato = output.ImportFromProj4("+proj=tmerc +lat_0=53.5 +lon_0=-8
+k=1.000035 +x_0=200000 +y_0=250000 +a=6377340.189 +b=6356034.447938534
+towgs84=482.530,-130.596,564.557,-1.42,-0.214,-0.631,8.15 +units=m +wktext
+no_defs <>)");   // IG
CoordinateTransformation tra = new CoordinateTransformation(input, output);
double[] xy = new double[3];
xy[0] = 600000.0;
xy[1] = 700000.0;
xy[2] = 0;
tra.TransformPoint(xy);
After execution xy[0]= 200040.069 and xy[1]= 199964.097. This is about 9
meters off in east and 1.7 in north.
Any reason why I should get 2 different results?
Regards
Bjørn
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20110127/fa3d93fe/attachment.html>
