[Proj] Esri & EPSG Proj codes
Sat Sep 10 09:39:54 PDT 2011
On 11-09-10 09:12 AM, Irwin Scollar wrote:
> Melita Kennedy wrote in reply to my query concerning Esri proj codes:
>> There currently is not a complete list available online. The
>> ArcObjects enumeration lists are not complete. These are definitions
>> defined by Esri. Sometimes EPSG adds the definitions later, and then
>> Esri updates the well-known IDs to the EPSG one (as more authoritative).
> The Access database EPSG-v7_9.mdb contains 4924 COORD_REF_SYS
> codes.  4416 of these have Proj data which can be gleaned by
> combining the epsg and esri lists from the NAD directory out of a
> total of 6577 codes in these lists, eliminating "Unknown",
> "Unspecified" and searching for all correspondences between the NAD
> code numbers and the EPSG code numbers.
> How were the esri and esri-extra lists in that directory obtained?
Irwin,
I believe I generated these PROJ.4 init files.  I ran a script to
process a directory full of ESRI projection engine .prj files from
some ESRI product.  This was done a number of years ago and I have
not attempted to update them.
> When EPSG adds definitions defined by Esri, do these get new numbers
> in the EPSG Access database or is there a systematic relationship
> between Esri numbers prior to adoption by EPSG and after
> incorporating them in the EPSG database?
I can't say authoritatively, but I assume they are renumbered.  I believe
ESRI deliberately chooses numbers well outside the EPSG norm and EPSG
assigns numbers in their normal ranges when they incorporate the coordinate
systems into their master database.
Best regards,
light and sound - activate the windows | http://pobox.com/warmerda
and watch the world go round - Rush    | Geospatial Software Developer
