[Proj] Errors in mod_ster
OvV_HN ovv at hetnet.nl
Sun Sep 11 03:03:10 PDT 2011
In reply to:
[Proj] Projection gs48 error?
Frank Willett fyw at wwwtools.com
Sat Sep 10 10:36:42 EST 2011
and:
[Proj] Problem with alsk projection
Fri Sep 9 11:17:03 EST 2011
Indeed, there are errors in several sections of PROJs and libprojs mod_ster.
See my posting dated Feb 17, 2008; 9:31am,
subject:  Small errors in modified stereographic
The phi0 in GS48 should be 39.0 instead of -39.0
The value of A3 in Lee should be -0.00881625 (not -0.0088162).
Reference: J. P. Snyder: Map projections, a working manual, PP 1395, Ch. 26,
p. 209.
Nobody was interested at that time and the errors remained.
I will not "file a ticket" or whatever the bug reporting procedure is
called.
Why ALSK gives an incorrect answer in some cases, I don't know.
My own mod_ster function is derived from GCTP and its mod_ster function just
works better.
Oscar van Vlijmen
