[Proj] Error when make check
brick brickflying at gmail.com
Tue Sep 27 02:29:35 PDT 2011
Hi
I met an error when make check. My system is CentOS 32bit. Intel compiler is
used. Does anyone know the reason. Thanks. Here is the command I use:
         ./configure --prefix=$ProPathDtl --enable-static=yes
--enable-shared=no >& $RunPath/Proj-$Vproj.Conf
         make >& $RunPath/Proj-$Vproj.Make
         make check >& $RunPath/Proj-$Vproj.MakeCheck
         make all install >& $RunPath/Proj-$Vproj.MakeAllInstall
./testvarious ../src/cs2cs
Running ./testvarious using ../src/cs2cs:
doing tests into file tv_out, please wait
diff tv_out with tv_out.dist
25,26c25,26
< 0d00'00.000"W 0d00'00.000"N 0.0       6378137.00      0.00 0.00
< 0d00'00.000"W 0d00'00.000"N 10.0      6378147.00      0.00 0.00
> 0d00'00.000"W 0d00'00.000"N 0.0       6378137.00      -0.00 0.00
> 0d00'00.000"W 0d00'00.000"N 10.0      6378147.00      -0.00 0.00
28c28
< 0d00'00.000"W 90d00'00.000"N 0.0      0.00    0.00 6356752.31
> 0d00'00.000"W 90d00'00.000"N 0.0      0.00    -0.00 6356752.31
PROBLEMS HAVE OCCURED
test file tv_out saved
make[2]: *** [check-local] Error 100
make[2]: Leaving directory
`/home/qiuxb/qw01/Program/IntelCompiled/Temp/proj-4.7.0/nad'
make[1]: *** [check-am] Error 2
make[1]: Leaving directory
make: *** [check-recursive] Error 1
Thanks.
brick
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20110927/bfa52615/attachment.html>
