[Proj] Error when make check
Eric Miller EMiller at dfg.ca.gov
Tue Sep 27 08:38:16 PDT 2011
It appears to be a problem with the test script.  As floating point numbers, minus zero and positive zero compare equal.  But, as text, they are different.
Eric G. Miller
Staff Programmer
CA Dept. of Fish & Game
>>> On 9/27/2011 at  2:29 AM, brick <brickflying at gmail.com> wrote:
> Hi
> I met an error when make check. My system is CentOS 32bit. Intel compiler is
> used. Does anyone know the reason. Thanks. Here is the command I use:
>          ./configure --prefix=$ProPathDtl --enable-static=yes
> --enable-shared=no >& $RunPath/Proj-$Vproj.Conf
>          make >& $RunPath/Proj-$Vproj.Make
>          make check >& $RunPath/Proj-$Vproj.MakeCheck
>          make all install >& $RunPath/Proj-$Vproj.MakeAllInstall
> ./testvarious ../src/cs2cs
> Running ./testvarious using ../src/cs2cs:
> doing tests into file tv_out, please wait
> diff tv_out with tv_out.dist
> 25,26c25,26
> < 0d00'00.000"W 0d00'00.000"N 0.0       6378137.00      0.00 0.00
> < 0d00'00.000"W 0d00'00.000"N 10.0      6378147.00      0.00 0.00
>> 0d00'00.000"W 0d00'00.000"N 0.0       6378137.00      -0.00 0.00
>> 0d00'00.000"W 0d00'00.000"N 10.0      6378147.00      -0.00 0.00
> 28c28
> < 0d00'00.000"W 90d00'00.000"N 0.0      0.00    0.00 6356752.31
>> 0d00'00.000"W 90d00'00.000"N 0.0      0.00    -0.00 6356752.31
> PROBLEMS HAVE OCCURED
> test file tv_out saved
> make[2]: *** [check-local] Error 100
> make[2]: Leaving directory
> `/home/qiuxb/qw01/Program/IntelCompiled/Temp/proj-4.7.0/nad'
> make[1]: *** [check-am] Error 2
> make[1]: Leaving directory
> make: *** [check-recursive] Error 1
> Thanks.
> brick
