[Proj] Confused about geos projection documentation
Frank Willett fyw at wwwtools.com
Wed Apr 25 08:56:55 PDT 2012
Hi All,
In the new documentation for the geos projection at:
http://trac.osgeo.org/proj/wiki/proj%3Dgeos
I'm confused because it contains the following two statements:
sweep: the sweep angle axis of the viewing instrument. Can be x or y
(x is the default). (new in 4.8.0)
and
The sweep argument is used to tell proj.4 which on which axis the
outer-gimbal is rotating. The possible values are x or y, y being the
default.
Which of these statements is correct?
Thanks for your input :-)
Frank Willett
