[Proj] Confused about geos projection documentation
Martin Raspaud martin.raspaud at smhi.se
Wed Apr 25 09:57:19 PDT 2012
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 25/04/12 17:56, Frank Willett wrote:
> Hi All,
> In the new documentation for the geos projection at:
> http://trac.osgeo.org/proj/wiki/proj%3Dgeos
> I'm confused because it contains the following two statements:
> sweep: the sweep angle axis of the viewing instrument. Can be x or
> y (x is the default). (new in 4.8.0)
> and
> The sweep argument is used to tell proj.4 which on which axis the
> outer-gimbal is rotating. The possible values are x or y, y being
> the default.
> Which of these statements is correct?
Hi Frank,
Indeed, this is confusing. At the moment, the default is x because of
a misunderstanding when submitting the patch. I send another patch to
change this to y, but it didn't make it in 4.8.0 as I hoped.
However, it is just a naming matter. The name x and y should just be
exchange, and this is what the latest patch is supposed to do. So that
not providing the +sweep argument would result is the same value
before and after the patch.
So, I will change the documentation to reflect the current state,
hoping that the last patch will make it soon in a 4.8.1 release...
Best regards,
Martin
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.14 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iQEcBAEBAgAGBQJPmCzuAAoJEBdvyODiyJI4bmsIAKoC2+u1SAf2W4O385ZQp+kF
lMCaLifyUPHzDlL2ZpyweOL6l//jvWzioHkwD/UzQEkWsdqxc0cfYJ4KnTOByDPb
2Iv0PB7lqKsjYSTuANPE/YrwdXgikC4VWOH6nGfDDwzUEV/HEpczpbRqN6NRk41M
WUJ8eYmdcn67cWViVNVRFKxbOL243Z1Uj0GaU8bwpfgrAf9MPW/ZcSfhohdKPOlD
rQ88mtC/AbBxXyYCKtJonWDPJbVZ1Ar5XA2WGztOnGdcEgttbpN8eacshjxf0K5F
0CYx87m4aWfmxbnEMk7idHxpYopwJ29qygVscRoUOitbrIUQqHM8jsjMiOGt2TY=
=ZIaB
-----END PGP SIGNATURE-----
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20120425/655e0841/attachment.vcf>
