[Proj] Proj Release
Jeff McKenna jmckenna at gatewaygeomatics.com
Tue Feb 21 12:24:14 PST 2012
Thanks Frank, I am able to compile now.
I notice that the PROJ_LIB_DIR isn't used (the 'install' target in
makefile.vc creates a 'share' folder but nothing is copied to it)...so I
have removed any reference locally to PROJ_LIB_DIR and that share folder.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 12-02-21 2:05 PM, Frank Warmerdam wrote:
> Folks,
> It seems I botched a fix commit on windows.  To get things working
> it should be sufficient to apply the following two changes.  One backing
> out my misdirected commit, and one applying the intended fix.
>    http://trac.osgeo.org/proj/changeset/2169
>    http://trac.osgeo.org/proj/changeset/2170
> The problem should only affect MSVC builds.
