[Proj] Proj Release
Martin Raspaud martin.raspaud at smhi.se
Thu Feb 23 02:36:08 PST 2012
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 22/02/12 17:55, Frank Warmerdam wrote:
> On 12-02-22 06:27 AM, Martin Raspaud wrote:
>> Hi Frank,
>> Here is a patch for the aforementioned feature.
> Martin,
> Very quick! Could you file this as a ticket at http://proj.osgeo.org/
> please?
>> Two questions though:
>> - - How and where do I change the documentation ? I'm not sure I've seen
>> documentation for the geos projection somewhere...
> An excellent question and one that has been neglected.  For the healpix
> projection the documentation was added in the FAQ but I think this will
> be unwieldy in the longer term.  I have created a ProjectionsList wiki
> page which for now will be the home to docs for new projections added to
> PROJ.4.  At some point we might also add wiki docs for existing common
> projections.
>    http://trac.osgeo.org/proj/wiki/ProjList
>> - - Are there unittests I need to modify/add to ?
> I would appreciate adding a brief test of new projections in
> proj/nad/testvarious with the results in tv_out.dist.
> Best regards,
Hi Frank,
I created ticket #146 for this issue. I attached there an updated
version of the patch, including a small change to the previous patch I
send (so please disregard the old one), unit tests and results.
I also added the proj=geos page to the ProjList. You're very welcome to
have a look at it and give some feedback:
http://trac.osgeo.org/proj/wiki/proj%3Dgeos
Best regards,
Martin
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.14 (GNU/Linux)
Comment: Using GnuPG with Red Hat - http://enigmail.mozdev.org/
iQEcBAEBAgAGBQJPRhaYAAoJEBdvyODiyJI4fl4IAJWT72k4dpVfmBNIkSaC1VFO
ki5yiZDlhVcREupoCKoQD/x5xsxYm0acktnRNjhEE5JBZqSzt8i264yt2e9HKD/P
Hrc6R6eeRGxB5cJXBDeb15oDz+VQ4ZEwH8Gbr9Nin4xPR4yqooEflTqaVhyYXwNQ
s89//MpyTRcVM+8usf0AfI3JDuYlJhP+y4Ih0dCm9JTIxzpNifDn1thuS/Tqjfg2
VDwJ7hi7BLYexnLuGSnFRTAxxIZdwDemnCgMOuTzrO8o7XAa5if+L2Csm3WL6cnb
/KxWgeu2VSVhJ2TBJkrIG6Pm+j9uADlfNf7bgt40DSyrOgooMOFZxMBL0/jam4o=
=CT7N
-----END PGP SIGNATURE-----
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20120223/aebf57a1/attachment.vcf>
