[Proj] Vertical Datum Shift
Thomas Knudsen knudsen.thomas at gmail.com
Tue Jan 10 23:39:19 PST 2012
2012/1/10 Michal Seidl <michal.seidl at gmail.com>:
> In my case I did not
> the last step make install to prevent currently installed packages from
> Ubuntu repository.
I haven't tested this for proj, but usually you can do a "per user
install" in ~/bin, ~/man, etc. by running the configure script as
./configure --prefix=$HOME, then prepend the ~/bin directory to your
path variable.
hth/thomas
