[Proj] Vertical Datum Shift
Michal Seidl michal.seidl at gmail.com
Tue Jan 10 14:19:28 PST 2012
I also started playing with vertical datum just about week ago, so I have
this experience.
+geoidgrids works with proj4 version 4.8.0. Now the trunk version in SVN
repository. Download and run ./configure, make on linux machine from top
directory. (have no idea how on Windows).  You will find compiled binaries
at src folder. Than run this executable for testing. In my case I did not
the last step make install to prevent currently installed packages from
Ubuntu repository.
You have to use PROJ_LIB=<path to nad directory> to force new compiled proj
to see your gtx file.
Hope this help. Michal
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Vertical-Datum-Shift-tp7096989p7174076.html
Sent from the PROJ.4 mailing list archive at Nabble.com.
