[Proj] Help w/Timbalai 1948
OvV_HN ovv at hetnet.nl
Sat Jul 28 04:21:30 PDT 2012
Re:
Mikael Rittri Mikael.Rittri at carmenta.com
Fri Jul 27 15:36:18 EST 2012
I tried the predefined instance of the latest Proj version, 4.8.0, like this
(where
the -f stuff just gives more decimals):
>proj +init=epsg:29872 -f "%.3f"
114.4   4.175
1718563.021   1515793.018
This is nearly the same as Oscar van Vlijmen's result, except for about 5
millimeters.
Reply:
There still might be an explicable, but larger difference though.
I assumed that the coordinates were on the Everest ellipsoid.
An epsg:29872 init suggests however that the original coordinates could have
been on the wgs84 ellipsoid.
In this init a datum transformation is defined and this will be executed if
a cs2cs is done, so I believe.
I didn't do a datum transform.
If the given lat,lon are on the WGS84 ellipsoid and a datum transform to
Timbalai 1948 is executed first, then the RSO coordinates will be (if I've
done everything correctly):
1717442.659, 1516072.998 sears feet.
Oscar van Vlijmen
