[Proj] Help w/Timbalai 1948
Mikael Rittri Mikael.Rittri at carmenta.com
Sun Jul 29 12:20:57 PDT 2012
Oscar,
I agree, except that I used the old proj command instead of cs2cs, so I didn't
get any datum shift.
But I can do
> cs2cs +init=epsg:4326 +to +init=epsg:29872 -f "%.3f"
114.4   4.175
1717442.731   1516073.010   -151.645
to perform the datum shift, too. Again, this agrees pretty well with your result,
but not exactly.
By the way, the datum shift one gets from +init=epsg:29872 is the one EPSG calls
"Timbalai 1948 to WGS 84 (4)" or EPSG:1852, with accuracy 5 meters,
and Area of Use: East Malaysia - offshore South China Sea.
Regards,
Mikael Rittri
Carmenta
Sweden
http://www.carmenta.com
28 jul 2012 kl. 13:22 skrev "OvV_HN" <ovv at hetnet.nl>:
> Re:
> Fri Jul 27 15:36:18 EST 2012
> I tried the predefined instance of the latest Proj version, 4.8.0, like this
> (where
> the -f stuff just gives more decimals):
>> proj +init=epsg:29872 -f "%.3f"
> 114.4   4.175
> 1718563.021   1515793.018
> This is nearly the same as Oscar van Vlijmen's result, except for about 5
> millimeters.
> Reply:
> There still might be an explicable, but larger difference though.
> I assumed that the coordinates were on the Everest ellipsoid.
> An epsg:29872 init suggests however that the original coordinates could have
> been on the wgs84 ellipsoid.
> In this init a datum transformation is defined and this will be executed if
> a cs2cs is done, so I believe.
> I didn't do a datum transform.
> If the given lat,lon are on the WGS84 ellipsoid and a datum transform to
> Timbalai 1948 is executed first, then the RSO coordinates will be (if I've
> done everything correctly):
> 1717442.659, 1516072.998 sears feet.
> Oscar van Vlijmen
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
