[Proj] proj4 api issue converting between state plane and wgs84
jdb1a1 jdb1a1 at gmail.com
Tue Jun 5 12:35:58 PDT 2012
Well, I tested out the same code base in with a wrapper for c# in proj4 and
it works fine.  I am going to process it on the server instead.  If anybody
knows why this didn't work in the Proj4 C API, I would still love to know.
View this message in context: http://osgeo-org.1560.n6.nabble.com/proj4-api-issue-converting-between-state-plane-and-wgs84-tp4979285p4979307.html
Sent from the PROJ.4 mailing list archive at Nabble.com.
