[Proj] proj4 api issue converting between state plane and wgs84
support.mn at elisanet.fi support.mn at elisanet.fi
Thu Jun 7 05:35:12 PDT 2012
Hello,
if I correctly remember there was some special trick to be done with the "longlat" projection
before you could use the output... the long and lat result was divided by the ellipsoid axis
or something... so basically you should do the reverse.. check the source code to find out
more..
regards: Janne.
jdb1a1 [jdb1a1 at gmail.com] kirjoitti:
> Well, I tested out the same code base in with a wrapper for c# in proj4 and
> it works fine.  I am going to process it on the server instead.  If anybody
> knows why this didn't work in the Proj4 C API, I would still love to know.
> View this message in context: http://osgeo-org.1560.n6.nabble.com/proj4-api-issue-converting-between-state-plane-and-wgs84-tp4979285p4979307.html
> Sent from the PROJ.4 mailing list archive at Nabble.com.
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
