[Proj] PROJ.4: pj_transform parameters
nicolas david ericnico.david at gmail.com
Thu Oct 4 10:32:10 PDT 2012
sorry a missing slash http://spatialreference.org/ref/epsg/4326/ should
work better.
But you could also search on the epsg file on your nad directory,
# WGS 84
<4326> +proj=longlat +datum=WGS84 +no_defs  <>
2012/10/4 Doanh Hoang <doanh.hoang at mud-maps.com>
> Hi David.
> Thank you for quick support !
> Is it right that for another datums (for example : NAD27, NAD83, OSGB, ED
> 50, etc,...) we can do transformation with only just simple initialization
> like projPJ src= pj_init_plus( "+init=epsg:4326"); (I mean that we use
> only +init parameter)
> Clicking on http://spatialreference.org/ref/epsg/4326 I get :  " Not
> found, /ref/epsg/4326. "
> Doanh
> On 4 October 2012 23:48, nicolas david <ericnico.david at gmail.com> wrote:
>> Hi
>> On our proj4 installation you should have a directory call "nad". This
>> directory have some dictionnary of projection that could be used to define
>> projection parameters. For exemple with the lat/long wgs84 projection you
>> could use
>> see http://spatialreference.org/ref/epsg/4326 for searching your
>> projection code.
>> Take care of setting the PROJ_LIB environnement variable to the correct
>> path for your projection directory.
>> Nicolas
>>>  Hi all
>>> Im developer and this is the first time I touch PROJ.4 . And I have
>>> following problem , please anyone can give me an advice:
>>> In my project I need to do *transformation from datums  (US, North
>>> America, UK, South Africa, New Zealand) to WGS84. *
>>> After having a look at defintion of pj_transform  (function to do datums
>>> transformation on PROJ.4). I have seen that there are so many input
>>> parameters.
>>> For example : following code that I found in internet :
>>>     projPJ src= pj_init_plus("+proj=tmerc +lat_0=38N +lon_0=128E
>>> +ellps=bessel +x_0=400000 +y_0=600000 +k=0.9999
>>> +towgs84=-146.43,507.89,681.46");
>>>     projPJ dst= pj_init_plus("+proj=latlong +datum=WGS84 +ellps=WGS84");
>>>     double x,y,z;
>>>     x=100;
>>>     y=100;
>>>     z=100;
>>>     pj_transform(src,dst,1,1,&x,&y,NULL);
>>>   params for initionlization of datums
>>> +proj=merc +ellps=clrk66 +lat_ts=33  +proj=latlong +ellps=clrk66 ------------------------------------------------------------------------------------------------------
>>> There are so many geospatial knowledge neccessary to understand these
>>> parameter.
>>> Im developer and I know just only the simple name of datums(WGS84,
>>> NAD27, NAD83, etc,..) and coordinates of points,
>>> With them how I can make transformation between different datums ? *Where
>>> I can get input parameters and define correct geospatial input parameters.
>>> I very need your help. Thanks a lot.
>>> Hoang Doanh
>>> Proj mailing list
>>> Proj at lists.maptools.org
>>> http://lists.maptools.org/mailman/listinfo/proj
>> Proj mailing list
> Proj mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20121004/212b4b05/attachment.html>
